Monitor XCOM
sundarv1
Guide
we have below xcom running in Linux env. but it is not listed as process under the host.
How do we monitor this in dynatrace?.
6 REPLIES 6
Yosi_Neuman
Hi @sundarv1
Please check Which are the most important processes? to understand why your process is not monitored OOTB.
Dynatrace provides the option of monitoring specific processes that is not mark as important process.
HTH
Yos
Hi Yosi
Xcomd process is running in the server and but it is listed in the host level process.
I did do the declarative process grouping and but it is not work.
Could you please provide screenshot how to configure my xcomd in the declarative procees
Hi @sundarv1
I would try Simple detection rules or Advanced detection rules
HTH
Yos
Hi Yosi
I am taking about unix process monitoring. not java monitoring. Please find attached steps which i did and but it is not working.
It was just and example .....
May be your executable path is not right? i.e. include also the executable name not only the path?!
Any how you can try other process properties
And finally be sure to restart the xcom process in order to check you declarative or any other process setting.
HTH
Yos
Remember those changes will be applied when you restart process.
Best regards
