07 Feb 2024 09:01 AM - last edited on 07 Feb 2024 12:29 PM by MaciejNeumann
I want to create a visualization for our application platforms having apdex overview..
Is there any way to do it using grail or new functionality rather than configuring it in Data explorer.
Regards
Amita Chede
07 Feb 2024 09:28 AM
Hi @amita
I do not see a direct advantage of Grail over Data Explorer when building charts for Apdex.
You can think of your own application in Dynatrace built on AppEngine.
Radek
07 Feb 2024 09:45 AM
Thanks for the quick response Radek.
Regards
Amita
15 Apr 2024 12:43 PM - edited 15 Apr 2024 12:47 PM
Useful resources:
https://community.dynatrace.com/t5/Developer/ct-p/developers
https://community.dynatrace.com/t5/DQL/bd-p/dql
https://community.dynatrace.com/t5/Automations/bd-p/automations
08 Feb 2024 10:24 PM
I assume you want to show Apdex values for applications or user actions on a dashboard.
Currently (Feb 2024) Apdex metrics or user session data are not yet in Grail and you can't easily visualize it on the new dashboards or notebooks. For visualizing Apdex it's still recommended to use Data Explorer + Dashboard classic or USQL.
There are workarounds using JavaScript as the data source, but I highly discourage you from using them unless necessary.
09 Feb 2024 08:21 AM
Understood.
Is there any chance Dynatrace is planning to get the user session data in grail in nearby future.
09 Feb 2024 05:41 PM
Yes, it will be available soon.
15 May 2024 04:24 PM
Hi Julius, do you have any update on the release period of it?
Thanks in advance
15 May 2024 04:47 PM
Would you know if there are any target dates for metrics that are being moved over to grail?
