18 Apr 2024 06:50 PM - last edited on 10 May 2024 02:50 PM by Michal_Gebacki
Hi I'm running into an issue with the new MQ extension version 3.3.1. I have 5 queue managers running on a single server. When I do a new configuration for each queue manager I am getting a green button OK for each, but when I go to the dashboard only one of the queue manager's is showing up. Is there anyone who has run into the same issue, and where you able to resolve it?
19 Apr 2024 06:28 PM
Hi @david_petty ,
Most likely permissions but the logs will confirm.
There are some things you can check and the Dynatrace Hub Tile for the extension has a FAQ & Troubleshooting portion you can try. If after you've tried that, it still doesn't work, you'll have to open a Support ticket.
Diego
