on 05 Jun 2023 06:44 PM - edited on 20 Feb 2024 08:39 AM by PavloM
When uing Synthetic Monitoring, it is sometimes necessary to allow/ allowlist traffic for Browser and HTTP monitors to execute successfully and return data to Dynatrace. For RUM, this is described here. Synthetic uses the same technology to return data to Dynatrace, so the RUM rules should also be used.
In this article, we will only describe the extra contraints for Synthetic.
Issue Solution Tasks Alternative(s)
Synthetic monitors fail to reach application | Allow/ allowlist connection | Confirm what is being blocked. Change configuration | Raise a support ticket or contact us via chat. |
Synthetic Monitor data is not returned to Dynatrace | Allow/ allowlist connection/ traffic | Confirm what is being blocked. Change configuration | Raise a support ticket or contact us via chat. |
There are many types of failures that can show in a Synthetic Monitor for this, they could be request timeouts, authentication failure, connection refused etc. The key thing is that the monitor is permanently failing with the same outage.
What can you do?
Confirm with the following with the relevant Application team:
We recommend allowing our traffic by either allowing access by User Agent string or IP address.
As well as the checks for public locations, here are some helpful tests you can try from your private location.
Use this command to confirm if the connection issue is related to Dynatrace or the machine itself.
curl -vki <url you are testing>
or if you are using a proxy:
curl -vki -U proxyUser:proxyPassword -x proxy:proxyPort <url you are testing>
if the site is redirected to another page, you will need to add -L to follow redirects also. For example,
curl -vki -L <url you are testing>
What can you do if the result of the command fails
If the curl commands, then the issue lies in the connection between the machine and the application you are testing. Here's what you can do to fix it:
If the result of the command is successful
curl -vki <url you are testing> -H "User-Agent: DynatraceSynthetic/1.267.13.20230518-162314"
curl -vki <url you are testing> -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/113.0.0.0 Safari/537.36 RuxitSynthetic/1.0 v0 t0 cfeatureHash=7efgijmoqtvx caes=1 ccux=1 sia=1 smf=1"
What can you do if the result of the command fails? you will need to allow/ allowlist our User-Agent string on your Application/ Firewall.
If you are working on Windows, you may only have the option of Powsershell instead of curl. You can use Invoke-Webrequest.
without proxy:
Invoke-WebRequest -Uri "<url you are testing>"
with proxy:
Invoke-WebRequest -Proxy "<proxy-url>:<proxy-port>" -ProxyUseDefaultCredentials -Uri "<url you are testing>"
with redirects following and printing raw response:
Invoke-WebRequest -MaximumRedirection 10 -Uri "<url you are testing>" | Select-Object -Expand RawContent
Invoke-WebRequest -Uri "<url you are testing>" -Headers @{"User-Agent"="DynatraceSynthetic/1.267.13.20230518-162314"}
Invoke-WebRequest -Uri "<url you are testing>" -Headers @{"User-Agent"="Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/113.0.0.0 Safari/537.36 RuxitSynthetic/1.0 v0 t0 cfeatureHash=7efgijmoqtvx caes=1 ccux=1 sia=1 smf=1"}
If your Synthetic ActiveGate has a GUI, you can test Browser Monitors from there. This is usually the case for Windows ActiveGates so I will just focus on those.
PsExec.exe -i -u "NT Authority\LocalService" "C:\Program Files\dynatrace\synthetic\Chrome-bin\chrome.exe"
(If you installed the synthetic location in a non-standard path you need to adapt the path to chrome.exe)
For SaaS tenants
if you can't find a cause, open a chat or create a ticket.
For Managed tenants
Confirm that Cluster ActiveGate url is publicly available. It can be limited to access from public locations IP addresses, if needed.
Confirm that the Synthetic endpoints are all open
beacon/[uuid]
Synthetic health checks /beacon/synthetic/[uuid]
HTTP Monitors /beacon/synthetic/httpresults[uuid]
screenshots /beacon/synthetic/screenshot/[uuid]
Browser Monitors /beacon/synthetic/browser/[uuid]
https://<Cluster AG Public Url>:<port>/beacon/synthetic/<environment UUID>?healthcheck&tenantId=<environment UUID>
and the response should be json like this
{"ts":1680601930205,"activeGateId":nnnn,"activeGateVersion":"1.261.166.20230308-123141","activeGateWorkingMode":"MANAGED","tenantAvailable":false,"syntheticLicenseAvailable":false,"rumLicenseAvailable":false,"rumConfigRevision":-1,"imgAvailable":false,"hmResultsAvailable":false,"failureScreenshotInterval":3600000,"clusterVersion":"","clusterUUID":"","jsAgentVersion":"","protoVersion":1,"httpMonitorsResultsPath":"","screenshotsPath":"","mpmResultsAvailable":false,"credentialsPath":""}
Once you've done the checks and determined the root cause of the problem, here are some possible solutions that you can apply
Synthetic Monitors can be recognised by the User Agent string they add in the request headers. This can be used in Firewalls etc to identify Synthetic traffic and allow it.
For Browser monitors, we add
RuxitSynthetic/1.0
and some extra parameters after that. You can find the full list here.
For HTTP Monitors, we add
DynatraceSynthetic/{version}
The version changes with each release, so you may wish to just use DynatraceSynthetic/. You can find the full list here.
IPs can be used to identify Synthetic traffic and allow it to pass through Firewalls etc.
You can find the IPs used by our public locations either using the Frequency and Locations page in the WebUI or the Synthetic locations API - GET all locations API call. You can find the further details here.
We do not list private location IPs but you can find them in the WebUI in Deployment Status> ActiveGates. You can then filter for either just the location you are interested in or all Synthetic ActiveGates and open each ActiveGate details tile to check the IP addresses.
If a proxy is needed to connect to your application or you need to bypass it, then you may need to add some further configuration to your proxy to allow access from the machine/ location.
If the proxy already has the necessary change made we provide information on setting up the ActiveGate to use different proxy connection scenarios here.
In addition to this, if you need to only enable the proxy settings for Monitors (both HTTP and Browser) or S3 (screenshot storage), you can add the following flags to ActiveGate Synthetic user.properties file
default Linux path: /var/lib/dynatrace/synthetic/config/user.properties
default Windows path: C:\ProgramData\dynatrace\synthetic\config\user.properties
com.vuc.proxy.s3.enabled=false com.vuc.proxy.monitor.enabled=true
The above snippet would enable Monitors to use the proxy settings specified in custom.properties but s3 would bypass the proxy and use a direct connection.
There is no separate setting for Browser and HTTP Monitors at this point, however, Browser Monitors can use PAC files, so this can be used to achieve a different proxy for HTTP Monitors and Browser Monitors.
For applications that need to be opened in a Browser started by a domain user, you can update the user that the Dynatrace Synthetic service logs on as.
IMPORTANT: This is unsupported by Dynatrace and will need to be re-configured every time the ActiveGate is updated. We recommend auto-update is disabled for these ActiveGates and a maintenance window created to cover the period of the update and re-configuring the log on user.
To revert to use the Local Service user
If all else fails and the error persistes, open a support ticket
