• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home
  • Public Forums
avatar image
Question by David C. · Aug 14, 2014 at 10:39 AM ·
PurePath Behavior When Crossing System Profiles
Here is the scenario:
We have two system profiles:
SystemProfile - Shipping Application
SystemProfile - My Application
If a PurePath is created in "My Application" and makes a web request to "Shipping Application" should it create a PurePath in the "Shipping Application" System Profile?
In our current "My Application", I can see that the PurePath indeed follows the trace into the "Shipping Application", however I would also expect to see a PurePath in the "Shipping Application". This is not currently happening. Could this be a support issue?
Is there a way to get the data to show up in both profiles? We have it set up this way due to security concerns. People with access to "Shipping Application" cannot be allowed to have access to "My Application".
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Rob V. · Aug 14, 2014 at 10:56 AM
Hi David,
The behavior that you're seeing is not unexpected. The "rule" for monitored instances is that if there is a call from one instance to another and those instances are being monitored on the same dT server, then they have to be in the same system profile. Otherwise, the behavior is often exactly what you see here: the PP started in Profile A will "steal" the PP that you expect to start in Profile B. That may not always happen, but it very likely will. The bottom line is that the installation you have here is not a supported one, so the behavior is undefined.
One solution to this if you want to get your desired behavior is to monitor the Shipping Application on a different dT server. Then you would see the outbound web request from My Application, and you would see a corresponding PP start in Shipping Application. Unfortunately you can't set it up so that you see the data showing up in both profiles.
Hope this helps,
Rob
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
