• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Ken L. · Aug 26, 2014 at 11:47 PM ·
Migrating from 5.5 to 6.0 General Questions
Hi, I have read through the deployment guide to plan for our upcoming 5.5 to 6.0 migration. I have a few questions.
1) Collector/Agent upgrades: As I understand the process, once the collectors are upgraded the bootstrap agents will auto upgrade but will not report as version 6.0 until the agents are restarted. The doc goes on to state that agents in an app must be of the same version or there will be broken purepaths. Does this mean that all jvms in an app must be restarted at the same time?
2) Deactivating License Key: We plan to do our upgrade during the off hours. In order to get an updated 6.0 license we must deactivate our current license. How can this be achieved during the off hours outage. IE Compuware not available to generate license key.
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Anton G. · Aug 29, 2014 at 04:36 AM
OK.  Can I just make sure about something.  When I upgrade an agent from 5.5 to 6.0 by restarting them, would it also update the bootstrap agent? Thus, do I have to re-install the v6.0 agent anyway to update the bootstrap part (so not the agent that is subsequently loaded) or will the bootstrap be updated and all the functionality of being able to connect to collector groups etc be in there?  Will this work the same for all agent types?
Comment
0 Show 1 · Share
avatar image Roman S. · Aug 29, 2014 at 05:27 AM 0
Share
Hi Anton,
No, restarting will not update the bootstrap agent. You will have to re-install 6.0 in order to get the bootstrap part updated so that collector groups etc work. It is the same for all agent types where we have bootstrap functionality.
Best, Roman
avatar image
Answer by Ken L. · Aug 28, 2014 at 12:44 AM
And one more question. Users currently connect to the qa and prod dt servers using the same local client. Once qa is upgraded, the client is 6.0. Must all local clients be upgraded to 6.0 and if so, can they still connect to the current 5.5 prod server. Or, is two local clients installations required, or prod webstart.
Comment
0 Show 1 · Share
avatar image Christian S. · Aug 28, 2014 at 01:40 AM 0
Share
I would use webstart clients for this use case. because otherwise you might run into problems somewhere.
avatar image
Answer by Ken L. · Aug 27, 2014 at 10:37 PM
thanks Christian. Is ok to run the 5.5 agent on a 6.0 collector. The issue for us is that we have 15 application in 11 system profiles. Each JVM is restarted in a rolling method, a few each week. In some cases it could take a month for all of the agents in an application to restart and get the upgrade. It is acceptable to run in this manner?
Comment
0 Show 1 · Share
avatar image Christian S. · Aug 28, 2014 at 01:38 AM 0
Share
sure, 5.5 agents can connect and talk to 6.0 collectors/servers! so it's absolutely possible to restart them step by step.
starting with 6.0 it's also possible to have a controlled rollout by selecting the agents that should be upgraded in the dynaTrace Client. so backwards compatibility is an absolute must have for the agents!
avatar image
Answer by Christian S. · Aug 27, 2014 at 10:25 PM
just to avoid any potential misunderstanding about the bootstrap:
  • when you upgrade the collector, all the agents keep running in their previous version (5.5) in your applications at first
  • as soon as your applications are restarted (not earlier!), the bootstrap agent (still version 5.5) will take care to inject the new agent (version 6.0)
best,
Christian
Comment
0 Show 0 · Share
avatar image
Answer by Ken L. · Aug 27, 2014 at 04:18 AM
Thank you Guenter.
This answers my questions.
Comment
0 Show 0 · Share
avatar image
Answer by Guenter H. · Aug 27, 2014 at 04:13 AM
Hi!
Q: As I understand the process, once the collectors are upgraded the bootstrap agents will auto upgrade but will not report as version 6.0 until the agents are restarted.
A: Correct. The new Agent will be injected into your app by the old bootstrap part. The Agent Overview will report a Bootstrap Version 5.5... and Agent Version 6.0.0.6738.
Q: The doc goes on to state that agents in an app must be of the same version or there will be broken purepaths.
A: Are you sure you read the right migration guide? This is only the case when you upgrade from 4.2!
Q: Does this mean that all jvms in an app must be restarted at the same time?
A: Not necessarily, but you should plan your upgrade around a maintenance window where you are able to restart your apps in close temporal fashion.
Q: In order to get an updated 6.0 license we must deactivate our current license. How can this be achieved during the off hours outage.
A: Even with the most simple upgrade alternative (which I recommend) you could deactivate your old license and upgrade it on eServices during daytime or on a Friday and run the dynaTrace Server on the three day grace period until you upgrade during off hours.
Hope this helps!
G.
Comment
0 Show 0 · Share
avatar image
Answer by Ken L. · Aug 27, 2014 at 01:14 AM
Thanks for the feedback Joel.
Just to be clear, all jvms will be upgraded at the same time, but the restart will be rolling over a week or so. I think the real question is the version effective immediately following the upgrade of the agent (bootstrap) or after the jvm is restarted.
Glad to hear from you
Comment
0 Show 0 · Share
avatar image
Answer by Joel B. · Aug 27, 2014 at 12:58 AM
Hey Ken,
1) During the upgrade, JVMs don't have to be installed at the exact same time, but for purepaths that begin before all tiers of the purepath are on the same version, you will likely have broken purepaths.
2) I suggest going to https://eservices.compuwareapm.com/.  At this website you can access all your company's license files, and manage the upgrade of the license files yourself.  Alternatively, you can upgrade the license files straight from the license tab in the dT client, as long as your credentials on the APM community allow you access to your license files.  If you need access, I'd encourage you to e-mail license_support@compuware.com to get your credentials added.
Hope all is well!
JB
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
3 People are following this question.
avatar image avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
