From time to time an aler triggered for a low-volume transaction stays active even is the situation is normalized:
In this case the response time alert stays active while it should not.
How can this be avoided?
Wim.
Answer by wim d. ·
Then suddenly the alert goes away:
Looking over a longer period of time:
The alert is triggered correctly, but the deactivation seems to take a very long time. I would expect that the alert ends at 13:00 (2 consecutive measurements below the baseline).
Wim.
