Good day
We want to use a Big Data solution for Business Transactions. I know we support Splunk and Hadoop. Have any one considered Microsoft Power BI? Is this someone has investigated yet?
Anton
Answer by Anton G. ·
Hi Martin
To store the data via the Business Transaction Bridge is exactly what we plan. I was hoping that someone has done it already and can tell me if it is a good solution or not.
I will let you know once we have done it.
Answer by Martin E. ·
Hi Anton,
unfortunately, we do not offer some sort of integration with the Microsoft Power BI. However, what you could try is to leverage the Dynatrace Business Transaction Bridge to store Business Transaction data from Dynatrace in a generic data format (e.g. csv or json) and import the contained records to your BI solution (there is broad support for these formats amongst BI solutions). You may also want to have a look at a recent webinar on "Integrating Dynatrace with Splunk" just to get an idea on how the data exchange from Dynatrace with other solutions basically works.
hth, Martin
