Answer by David M. ·
Hi Jibi,
Are you looking for something like this, DB Query Monitor Plugin? It looks like it'll give you the overall response time and the query response time.
Just thinking, you also may be able to create a measure for Database Time with the SQL Statement containing a Table Name/DB Name; this also supports regex.
David
