• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home
  • Public Forums
avatar image
Question by karthikeyan s. · Nov 25, 2014 at 12:38 AM ·
Connection Close between Collector and Agent
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Andreas G. · Nov 25, 2014 at 12:53 AM
Hi
I renamed and moved your question to the dynatrace Open Q&A forum.
To your question. This means that the physical connection between your Agent and this Collector was closed due to a Read Timeout. I think this typically happens when there is a problem with your agent, e.g: the application is no longer responding, it is crashed, ... and therefore our Agent is no longer responsive.
Can you look in the agent log files of that agent? You should find the log file on the machine where your agent is installed in the DTINSTALLDIR/log directory. Maybe there is an indication of what happened to that agent
Andi
Comment
0 Show 0 · Share
avatar image
Answer by karthikeyan s. · Nov 25, 2014 at 12:43 AM
I can see the collector instance was down between the particular time frame and in the collector instance log I can see the following line, could you please suggest what causing this issue.
2014-11-21 20:49:46 WARNING [Controller] Connection between controller and "agent agent" name closed.: com.dynatrace.diagnostics.collector.agentcenter.Controller a:644
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(SocketInputStream.java:152)
at java.net.SocketInputStream.read(SocketInputStream.java:122)
at java.io.BufferedInputStream.fill(BufferedInputStream.java:235)
at java.io.BufferedInputStream.read(BufferedInputStream.java:254)
at java.io.DataInputStream.readInt(DataInputStream.java:387)
at java.util.TimerThread.mainLoop(Timer.java:555)
at java.util.TimerThread.run(Timer.java:505)
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
