• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
This question was closed Feb 09, 2016 at 06:13 PM by Jason O. for the following reason: The question is answered, right answer was accepted
avatar image
Question by Jason O. · Nov 27, 2014 at 05:24 AM ·
Problems configuring DT Agent on Mule ESB - Mulesoft
I've already looked into a few postings about Mule ESB instrumentation (How to configure dynatrace agent in Mule ESB) , but I'm still having issues getting my agent running and connecting. I've installed the 64 bit Java Agent (and confirmed Java is 64 on this windows server), and in the wrapper.conf, utilized this as the argument:
wrapper.java.additional.8=-agentpath:"D:\NetApps\dynaTrace\dynaTraceAgent6.0.0\agent\lib64\dtagent.dll =name=MULEESBAPPINTG, server=10.251.88.223:9998"
We've checked that we can telnet from the agent to the collector on 9998 and still no connection to Dynatrace after restarting the Mule service. (I've double checked my agent mapping.
There is nothing in the agent logs, but I do get this in the collector logs:
2014-11-25 16:08:32 WARNING [AgentListener] Connection of Agent '(no agent)' refused: Ignoring connection that did not start with a dynaTrace agent handshake request (from /10.251.59.177:52031)
2014-11-25 16:19:49 SEVERE [AgentListener] Error setting up an agent connection from '(unknown)' at '10.251.59.177:52035': : com.dynatrace.diagnostics.collector.agentcenter.AgentListener$ConnectionHandler run:508
java.io.EOFException
at java.io.DataInputStream.readInt(DataInputStream.java:392)
at com.dynatrace.diagnostics.collector.agentcenter.AgentListener$ConnectionHandler.run(SourceFile:359)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
These timings to not match up with our agent restarts and might be due to something other than our agent. (Agent - Collector Handshake. "Collector declined service")
Has anyone else run into these problems with Mule ESB? I believe I'm having problems with getting my java agent up and running. What's a good way to diagnose this and ensure it is running?
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Best Answer
Answer by Jason O. · Dec 04, 2014 at 08:02 AM
We were able to resolve this issue. We still used the same configuration above (without spaces).  The only difference was that we started the instance using the mule script instead of the windows service. This allowed the agent to start up and connect.
Comment
0 Show 0 · Share
avatar image
Answer by Markus B. · Nov 28, 2014 at 09:08 AM
Hi
I suspect that the syntax is wrong. There are two space characters in the value of "wrapper.java.additional.8" (after dtagent.dll and before server=).
Markus
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
