• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Rick B. · Jan 23, 2015 at 05:51 AM ·
How many splitting values can auto-baselining handle?
Hi all,
I know in addition to "Application" we can only use one additional dimension, but how many splitting values can the auto-baselining handle?  Has this been investigated?
Rick B
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Kyle K. · Jan 23, 2015 at 05:54 AM
Rick are talking about before the auto base-lining would break? Because I would assume it is based off of the Splitting restriction options
Comment
0 Show 5 · Share
avatar image Rick B. · Jan 23, 2015 at 05:57 AM 0
Share
My fear is that if I set the splitting restriction too loosely (say max 5000) at some point the mechanism would slow down the server or the PWH operation times
avatar image Kyle K. Rick B. · Jan 23, 2015 at 06:01 AM 0
Share
Yeah that seems to make sense to me but I think those numbers may have been chosen as to not slow the entire application down. Whether or not that effects the auto-baselining differently or not I wouldn't know.
avatar image Klaus E. ♦ Kyle K. · Jan 24, 2015 at 01:07 AM 0
Share
Hi Rick,
The limit for the baselining is the same as for a normal BT. By default we cap a business transaction after 5000 split values. But I think your question goes more into the direction of how many splittings all BTs together generate that we have to baseline. Right?
Cheers Klaus
avatar image Rick B. Klaus E. ♦ · Jan 24, 2015 at 01:10 AM 0
Share
It wasn't but that's a good question!  I want to take advantage of this feature more and more, just want to make sure I'm not knocking anything over...
avatar image Klaus E. ♦ Rick B. · Jan 24, 2015 at 01:51 AM 0
Share
There is no exact threshold available for this as it depends on the sizing of the dt server and also on the number of splittings. What is important to also take into account is that in order to get a baseline each split has to produce enough values. Otherwise you won't get meaning full data. Talking to developers about this we said that in an environment that is running fine up to 50 000 split measures should not hurt but we doubt that this would make sense.
Klaus
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
3 People are following this question.
avatar image avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
