• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home
  • Public Forums
avatar image
Question by Matthew S. · Feb 10, 2015 at 10:55 PM ·
Collector on same LAN?
Do collectors HAVE to be on the same LAN as the agents (DT 6 instructions say it must)?
Just building a new DT installation and I was sure the collector didn't have to be on the same LAN!
Matthew
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Matthew S. · Feb 10, 2015 at 11:02 PM
Cheers Andi.. makes sense.
Comment
0 Show 0 · Share
avatar image
Answer by Andreas G. · Feb 10, 2015 at 11:01 PM
Hi Matthew
The key requirement is that you have low latency, high bandwidth between agent and collector. Why? because during agent startup we are sending the byte code (JAva, .NET) from the agent to the collector. The best case is that all is in the same LAN without any firewalls. However - that doesnt necessarily have to be the case as long as you have low latency and enough bandwidth between Agent and Collector. If that would not be the case startup time of your Agent will get delayed. If that takes too long we may also not instrument all classes as we stop after a while in case it is too slow and would impact your application
Please have a look at the Deployment Guide in the documentation for more information on our requirements
Andi
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
1 Person is following this question.
avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
