• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Michael S. · Mar 06, 2015 at 03:32 PM ·
Transaction Flow: show LDAP, SMPP and other binary protocols
We deal with a number of systems that communicate using binary protocols and would like them to show up in Transaction Flows and PurePaths. The main protocols we deal with are LDAP, SMPP and Diameter. In our test environments we have mock servers for these and I would like to include them in the information returned by Dynatrace.
For example we have a mock server in Java that listens to SMPP. It is deployed to a JVM with a Dynatrace agent and I have created a Sensor Rule for the method that is called on incoming SMPP requests. I made it active then ran Hot Sensor Placement. Here is a Transaction Flow:
I know that the components in the OCSG_NT agent group call our mock server and I would like those to show up in the Transaction Flow as well as the Oracle calls.
What else do I need to do?
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Andreas G. · Mar 06, 2015 at 06:33 PM
Just an FYI. Dynatrace 6.2 (Spring 2015) will provide the feature to mark custom sensors as "External Calls". it means that these method calls will be displayed as external tiers in the transaction flow
Comment
0 Show 0 · Share
avatar image
Answer by Rick B. · Mar 06, 2015 at 03:54 PM
I had an RFE that partially matches your specific use cases : RFE - Added transaction calls to Transaction Flow
The one Reinhard mentions that is more broad is here : Re: Transaction flow - external services for more protocols
Comment/vote on the above to bump them (smile)
Hope that helps,
Rick B
Comment
0 Show 0 · Share
avatar image
Answer by Reinhard W. · Mar 06, 2015 at 03:42 PM
Since these are binary/proprietary protocols you need to make sure the tags the dynatrace agent creates to trace transactions is carried over these protocols.
This can be done via our Tagging SDK but it requires source code change on your application side and also on the target application side. Using the tagging SDK involves putting the tag 'on the wire' of that protocol so that PPs can be correctly linked. Not every protocol might support adding additional data and in case of LDAP i think it might be tricky and not really providing lots of value to continue the PP on the LDAP server.
There is however a RFE (need to search for it) to define certain methods on the caller side as external calls so that you'll at least see the response timings for these and a 'external' service on the Transaction flow.
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
