I am trying to get Dynatrace dashboards running on a big screen TV connected to a thin client desktop through Citrix. Ideally without any manual input to get it up and running.
There is no problem launching the Client in kiosk mode, with a specific user and specific dashboards. I am having trouble with the Client remembering the connection information (host/port) and username/password. After restart of the OS, the Client goes back to localhost and admin username.
Where does the Client store this information? What files should my user be able to access or edit when getting this to work? If this is too sensitive, let me know and I will create a ticket with Support.
Best,
Jiri
Answer by Ahmed E. ·
Hi Jiri – Which Client are you using and on which OS? There are three different 'types' of the Client: 1/ Installed Client 2/ Portable Client 3/ Web Start Client. If you are using #1 on Windows, have a look in here: C:\Users\<YOUR_USER>\.dynaTrace\dynaTrace <VERSION>\client\conf\
Is that folder being cleared on reboot? Do the timestamps make sense?
