• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Juan B. · May 08, 2015 at 06:03 PM ·
Agent Connectivity Problems
We have our windows based web site hosted on 4 servers.  Although we can see on the monitoring/infrastructure dashboard details and basic performance metrics about the servers only one of the four machines is showing us purepaths/transactions.  Looking closer at the agent status we see the message:
The Agent is not correctly working because there's a shared memory related problem (details see logs)
Although the agent is connected we are not getting transactions captured when checking the purepaths. Any advice on this status message will be great. Where do we see the correct logs, is it within the System Information>System Profile>app profile log
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Christian S. · May 08, 2015 at 06:14 PM
no, you have to look into the agent log files, which are located in the system information dashlet under:
<server_name> - "connected systems" - <collector_name> - "connected systems" - <agent_name>
HTH,
Christian
Comment
0 Show 2 · Share
avatar image Juan B. · May 08, 2015 at 06:51 PM 0
Share
Thank you Christian, I can see the agent logs now. I think I opened the correct log and see the details below similar to the general memory problem I saw on the UI.  Any additional advice on the details below will be greatly appreciated.
015-05-06 21:15:53.765620 [129288/0000020c] info    [native] Shared memory file: F:\Program Files (x86)\dynaTrace2\dynaTrace Agent 5.5.0\agent\conf2015-05-06 21:15:53.765620 [129288/0000020c] info    [native] Master agent port: 80022015-05-06 21:15:53.765620 [129288/0000020c] info [native] Using SHM location: F:\Program Files (x86)\dynaTrace2\dynaTrace Agent 5.5.0\agent\conf2015-05-06 21:15:53.765620 [129288/0000020c] warning [native] Could not open file F:\Program Files (x86)\dynaTrace2\dynaTrace Agent 5.5.0\agent\conf: Access is denied.2015-05-06 21:15:53.765620 [129288/0000020c] severe  [native] Could not create or attach to shared memory segment. Using private data instead.2015-05-06 21:15:53.765620 [129288/0000020c] severe  [native] This means the shared memory segment used for communication between the web server agent and the web server module could not be created or attached to. Try deleting the file and make sure the agent has write permissions to it. The backing file used was: F:\Program Files (x86)\dynaTrace2\dynaTrace Agent 5.5.0\agent\conf2015-05-06 21:15:53.765620 [129288/00000264] info    [native] Loading collector peer list from f:/Program Files (x86)/dynatrace2/dynaTrace Agent 5.5.0/agent/conf/collectorlist.EIWEB174-ContractRatesPROD
avatar image Christian S. Juan B. · May 08, 2015 at 08:27 PM 0
Share
mhm, it's interesting why the shared memory file should be "F:\Program Files (x86)\dynaTrace2\dynaTrace Agent 5.5.0\agent\conf", which is usually just the config directory.
could you please check the following:
  • look into the file "F:\Program Files (x86)\dynaTrace2\dynaTrace Agent 5.5.0\agent\conf\dtwsagent.ini". is there a value to "SharedMemoryFileName" or is it commented out?
  • what are the permissions on the "F:\Program Files (x86)\dynaTrace2\dynaTrace Agent 5.5.0\agent\conf" folder? does the user which is running the web server processes have permissions to read files in this folder? it's best practice to set this folder and all files in it to be readable by all users.
HTH,
Christian
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
