Facing an issue with restarting the apache glassfish server.(cluster)-linux 6.4 version. after installing the agent in it.
Required cmd for running in linux servers
please suggest
Answer by Andreas G. ·
do you have any more specifics? It simply doesnt start anymore?
Can you let us know the "-agentpath:xxx" option you placed in glassfish. What I've seen in the past is that you either need to put the path to dtagent in "quotes" or you have picked the wrong bit-ness (32 vs 64bit) dtagent library. In the lib you will find the 32bit - in lib64 you find the 64bit agent. make sure you load the agent that matches the bit-ness of your Glassfish
