• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Vaibhav M. · Jul 27, 2015 at 05:59 PM ·
CPU Mismatch between Tagged Web Request and its purepaths
Our team noticed recently that when we open Tagged Web Request (lets call it TWR) dashlet, and pick a specific TWR and drilldown to its purepaths, the CPU Sum of TWR may not exactly match the combined CPU Sum of all the purepaths it drilled down to. This is happening for some of the TWR and not all of them.
On the other hand, for each TWR we have, the CPU Sum always exactly matches combined CPU Sum of all its Web Requests, which is good.
Similarly, if we drill down from purepaths (selecting all purepaths) to "methods" dashlet, the combined CPU Sum of all the methods exactly match that of the purepaths. This is also good.
So, it is the mismatch between TWR and Purepaths CPU Sum">CPU Sum which is bothering us. Some of the differences are huge starting from 400 ms going up to 4 sec.
We could not find any specific reason for this.
Can someone please clarify?
VM
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Graeme W. · Aug 03, 2015 at 07:59 PM
Vaibhav,
The dashboard I sent you was indeed 6.2.  My apologies!  I'm pretty sure you can change the version just by editing the XML, but anyway I'll get you a 6.1 version shortly.
There are several master-slave dashboards in the client, including the Load Testing dashboard and the Web Request Performance dashboard.  You get to the former from the Start Center, and the latter from the Web Request Performance link in the lower right of the monitoring "home page".  The feature is not documented, but it is available for internal use.
The dashboard I sent you won't give you the numbers you want in the REST interface.  If you want accurate numbers now, until the bug is fixed, I'd recommend you build your own PurePath business transaction splitting on the tags you want and build a new dashboard from that business transaction.
-- Graeme
Comment
0 Show 1 · Share
avatar image Vaibhav M. · Aug 14, 2015 at 09:24 AM 0
Share
Hi Graeme, Is there a defect Id which we could track to its implementation? Thanks.
avatar image
Answer by Vaibhav M. · Aug 03, 2015 at 12:07 PM
Hi Graeme,
I created the blank PP business transaction as you said. However, I was not able to open the dashboard after saving it locally. It gives "Unable to open/load 'TWR workaround' from <location>" error. Could be due to DT version mismatch, as I am using 6.1.0.7880 and yours is 6.2.0.1239.
Also, the concept of slave pane in TWR dashboard is new to me. I don't see any such option in my DT client.
On the other hand, if I am able to make this new dashboard work, the problem I will face is to get this slave pane data pulled via REST interface for each and every TWR. Any thoughts?
Vaibhav
Comment
0 Show 0 · Share
avatar image
Answer by Graeme W. · Jul 31, 2015 at 11:29 PM
Vaibhav,
I've built you a work-around dashboard, attached.  You'll need to build a blank PurePath business transaction – one with no extra filter, result or splitting measures – called All PPs.  Then you can open this dashboard, which is basically a copy of the Tagged Web Requests dashboard with a "slave" pane below it that shows the correct CPU data for whatever you click on in the upper pane.
Attachment:  TWR workaround.dashboard.xml
You'll also need to switch the dashboard source.
Let me know if this helps!
-- Graeme
Comment
0 Show 0 · Share
avatar image
Answer by Graeme W. · Jul 31, 2015 at 06:08 PM
Glenn,
I expect they'll fix the calculation – there's no precedent for displaying the current value anywhere other than the PP tree.
The issue also applies to the ordinary Web Request dashboard, so you got a twofer!
-- Graeme
Comment
0 Show 1 · Share
avatar image Vaibhav M. · Jul 31, 2015 at 06:50 PM 0
Share
Thanks Graeme.
Yes, we noticed about WR dashboard also. In fact, it might be how DT consolidates and shows data at TWR level !
So, until this fix is available, we need to add CPU Sum of all Purepaths belonging to a WR/TWR to get a more correct measurement of CPU for that WR/TWR.
Is that correct?
-- Vaibhav
avatar image
Answer by Glenn M. · Jul 29, 2015 at 11:27 PM
Thanks, Graeme.  There's no urgency, now that we understand the issue.  What exactly is the fix?  Is it just labeling, or the calculation itself?
Comment
0 Show 0 · Share
avatar image
Answer by Graeme W. · Jul 29, 2015 at 11:10 PM
Glenn,
It's a bug.  If you'd like a patch, you'll need to submit a support ticket.
Otherwise, you can wait for the fix to be rolled out in a regular release.  If you post here in a week or so, I can probably let you know when.
-- Graeme
Comment
0 Show 0 · Share
avatar image
Answer by Glenn M. · Jul 28, 2015 at 10:43 PM
Ok, this is interesting.  The PurePath contains 3 asynchronous threads, which are included in the Purepath's CPU Sum, but not in the Web Request's (or Tagged Web Request's) CPU Sum.  This is great information...it explains the sporadic differences we have been seeing.  Maybe the CPU Sum column for the Web Request and Tagged Web Request dashlets should be renamed to CPU Total?
Comment
0 Show 0 · Share
avatar image
Answer by Graeme W. · Jul 28, 2015 at 09:37 PM
Glenn,
The Tagged Web Request dashboard is taking the CPU sum value from the CPU total of the first thread.  You can see what's going on in the PP dashboard:
This is correct – Dynatrace is pretty consistent is using "total" to mean "including children" and "sum" to mean "all threads".  You can find the remainder of the PP CPU sum in the other threads lower down in the PP.
The question is, why is the Tagged Web Requests dashboard displaying the value for the first thread?
Could someone from R&D say whether this is a bug or works-as-designed, please?
-- Graeme
Comment
0 Show 0 · Share
avatar image
Answer by Glenn M. · Jul 28, 2015 at 07:00 AM
Here's a PurePath  APT20_ALL_CAVS [2015-07-20 17-45-45].dts
Comment
0 Show 0 · Share
avatar image
Answer by Graeme W. · Jul 28, 2015 at 01:49 AM
Glenn,
Is there any chance you can send us a PurePath so we can take a look at it?
If not, you might consider opening a support ticket.
-- Graeme
Comment
0 Show 0 · Share
  • 1
  • 2
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
