We have Dynatrace 4.2 with the Websphere MQ Monitor Plugin (1.0.3).
The collector has an MQ v7.5 installation. Also tried version 7.0.1 and tried both a client and full MQ installation on the collector. The remote MQ server is v7.5.
The collector service runs with a Windows AD amount that is:
a) Domain Admin (until this is working), and
b) A member of the Domain MQM group to allow MQ administrative access.
The plugin fails with the following error message:
“Could not retrieve queue manager Application. Manager status.”
From the DynaTrace collector server it is possible to run MQ explorer, connect to the remote “Application. Manager” queue manager and perform MQ administration tasks on its queues.
I would be grateful for any advice on how to troubleshoot this error.
Thanks, Kevin
Answer by Kevin M. ·
I've just checked and the current version of the Websphere MQ Monitor Plugin version 2.0.0. has been installed and has the same issue.
Regards, Kevin
Kevin,
Can you post the log files from the plugin here? Using the System Information dashlet in the dT client, you can look at all the log files. You will find the plugin log file under the collector that is running the plugin.
Thanks for your reply Asad,
I’ve sent the full log to you by email however the following is the last line from the log:
2013-02-04 14:19:20 SEVERE MQMonitorPlugin@U1 Websphere MQ Monitor_1 Could not retrieve queue manager 'XXXX.YYYY' status.
Thanks, Kevin
