Can anyone help me in installing browse agent for internet explorer version 7 on Windows XP (32 bit machine), we are currently using dynatrace version 5.5.0. I have already selected the Browser technology type in the system profile but was unable to see any add-on in the internet explorer.
Sitaram
Answer by Andreas G. ·
Also - here are some additional recommendations / steps you can try out
a) Install SP3 of XP and re-install agent
b) Open a command line prompt as administrator and verify that dtieagent.dll is installed in <dtInstallDirectory>\agent\lib. Then call the following command: regsvr32 /i dtieagent.dll
Andi
Hi - did you check the troubleshooting section on the following doc page? Browser Agent Configuration
