• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home
  • Public Forums
avatar image
Question by Prabhu B. · Oct 29, 2014 at 05:21 AM · web performance monitoring
Dynatrace not displaying proper delay for Web Request
Hi All,
Mine is a J2EE web application, which I am trying to monitor with by hooking up the DT Agent 6.0.0 to my JVM.
There is one particular business transaction that manually takes more than 30 sec to completed and I am trying to figure out (with help of DT) which method calls are taking more time. i  doubt that this transaction is doing lot of I/O and the method is suspended for  a while, which is why a high delay.
But to my surprise, if i look at the "Web Request" page I see all the sub-calls (URLs) getting listed but the Total Sum[ms] value for all the sub-urls is just few milli-seconds. This is weird and as it doesn't correlate with what i am getting from web browser
Even, I recorded that flow in LoadRunner and ran for few iteration in Vugen (just to check the delay without rendering factor) and every time i got same 30+sec response from my particular transaction. But somehow DT is not showing such high value in the results.
has anyone faced the same issue? do i need to change my Monitoring Group profile?
Prabhu
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by James D. · Oct 29, 2014 at 10:53 PM
Prabhu,
We had a similar problem using mod_proxy. There is a setting to increase the threads to the backend server. I have included both links to help.
The reason dynaTrace doesn't show a problem is because there isn't one. Your server is serving pages as fast as they can, however the proxy is limiting the number of concurrent.
http://httpd.apache.org/docs/2.2/mod/mod_proxy.html
http://httpd.apache.org/docs/2.2/mod/mpm_common.html#threadsperchild
Parameter Default Description
max 1...n Maximum number of connections that will be allowed to the backend server. The default for this limit is the number of threads per process in the active MPM. In the Prefork MPM, this is always 1, while with other MPMs it is controlled by the ThreadsPerChild directive.
Comment
0 Show 0 · Share
avatar image
Answer by Prabhu B. · Oct 29, 2014 at 10:35 PM
we have Apache service running that will act as proxy and converts https to http endpoint  and route it to the weblogic server where my application is hosted.
Comment
0 Show 0 · Share
avatar image
Answer by Andreas G. · Oct 29, 2014 at 12:26 PM
Hi. Do you have a web server (Apache, IIS, NGINX, ...) in front of your J2EE Server? If that is the case you could install a web server agent in that web server to see if time is lost in the web server. We have seen this many times that time is spent in tiers BEFORE the Java App Server. Web Server or even Load Balancers could be a problem.
Andi
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
1 Person is following this question.
avatar image
Related Questions
Release of JavaScript supported by dtagent_xxxx js
Long response time in User Action Purepath
dynaLearn Webinar - UEM Tips and Tricks error
Visit Coverage - Capture percentage of Visits
Client IP address via 'iv-remote-address'
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
