• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Kiran M. · Feb 26, 2015 at 01:08 AM · continuous delivery
Jenkins Build failing to establish connection with dynaTrace restful interface
We are able to telnet from Jenkins build box to the dynaTrace server box on port 80. I have checked the services–>Management in server settings and Allow non SSL connections is set to Port 80. The issue is when I try to test the dynatrace connection from Jenkins after adding a post build action is throwing an error saying "Connection with dynaTrace RESTful interface could not be established".
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by John G. · Apr 22, 2015 at 11:37 PM
I'm having the same experience but with using Hudson....I did save the dashboard as its own name...any thoughts?
Comment
0 Show 0 · Share
avatar image
Answer by Kiran M. · Feb 28, 2015 at 02:13 AM
Hi Wolfgang,
Thanks for giving me the right direction to find the issue. I found what was the problem. I was trying directly connect to default 'Test Automation' dashlet in dynaTrace. Because of which it was throwing that error. I have to save the default 'Test Automation' dashlet as a dashboard and tried connecting to the dashboard. The connection was successful.
Thanks!
Comment
0 Show 1 · Share
avatar image Wolfgang G. · Mar 02, 2015 at 09:53 PM 0
Share
Great to hear it worked out for you!
avatar image
Answer by Wolfgang G. · Feb 26, 2015 at 05:27 AM
This message can also mean that the username/password combination is wrong or the user is not permitted to use the REST interface. Could you try to verify that the password is correct and that the user has access to the rest api?
Comment
0 Show 4 · Share
avatar image Kiran M. · Feb 26, 2015 at 05:43 AM 0
Share
Thanks for the reply Wolfgang Gottesheim. I am able to launch the dynatrace in browser using same credentials.
avatar image Wolfgang G. Kiran M. · Feb 26, 2015 at 10:27 PM 0
Share
There should be some additional log messages in the Jenkins log (or on the command line). Any chance you could take a look there?
avatar image Kiran M. Wolfgang G. · Feb 27, 2015 at 01:12 AM 0
Share
The connection failure we are seeing before running the Jenkins build. So cannot view it in the logs.The error we are seeing when we click on the test dynaTrace connection. Attached is the screenshot.
avatar image Wolfgang G. Kiran M. · Feb 27, 2015 at 01:17 AM 0
Share
Hi Kiran,
I was referring to the Jenkins log itself (not the build log), you can get there through Manage Jenkins - System Log - All Jenkins log. I'll improve the output in the next version...
avatar image
Answer by Kiran M. · Feb 26, 2015 at 01:13 AM
CC:@Richard J.. Boyd . It is Jenkins plugin not Jenkins Build
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
3 People are following this question.
avatar image avatar image avatar image
Related Questions
Automation Client in an Intrumented app - how to get the app measures as test checkpoints?
DynaTrace 6.3 and Jenkins 1.625.3 connectivity issue
Two different Tests on Same Infra (System Profile)
PHP and Test Automation
Test Measures and Comparing Test Runs
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
