• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Dong L. · Sep 03, 2013 at 02:59 PM · business transaction
UEM Timing measures split by Tagged Web Request or Synthetic Test Step
I am working with a load testing customer, the overall response time from load test result seems high on average. the actual user experience seems not as bad as the load test result. As you know the load test scripts calculate all the timing factors such as server, network and third party. Customer is more interested on the true user experience of the load test scenario.
The idea data breakdown is to chart total time, server time, client time, perceived render time by script step.
The only close thing I can find is to chart those time by page action URL (which are all loading type). I do not see a way to split the UEM timing data such as perceived render time, document interact time by Tagged Gomez script step or server purepath. Any help will be appreciated.
If the above request is not doable, is there a way to chart perceived render time (and or total time, network time etc) split by page action name?
Dong
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Klaus E. · Sep 04, 2013 at 06:28 AM
Hi Liu,
The problem is that a script step can consist of multiple user actions and you are right on a server side PurePath you do not have perceived render time,...
What you can do is create a visit based BT that splits by page action name or page action target URI. This would allow you to calculate the values for total time, server time,...
Cheers Klaus
Comment
0 Show 1 · Share
avatar image Dong L. · Sep 04, 2013 at 05:59 PM 0
Share
Thanks Klaus.
I played around with a test, seems a page action based BT split by Tagged web requests works as I expected. See link at Re: Perceived Render Time by Synthetic Test Steps
Using visit based BT will return the same value for each tagged request (Tagged Web Request split by NA). Use page action BT seems return the average data
avatar image
Answer by Dong L. · Sep 04, 2013 at 04:51 AM
Andreas, Thanks, I reviewed the section but cannot find the charts/dashboard I need. I need to chart the timing (perceived render time specific) by Step Names (Gomez synthetic Test). Thanks
Comment
0 Show 0 · Share
avatar image
Answer by Andreas G. · Sep 04, 2013 at 04:27 AM
Hi. Have you looked at Gomez APM Integration?
There are some out of the box Business Transactions and Dashboards that you get in dynaTrace that will give you the information you request. It splits UEM User Actions by Test and Step Names
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Related Questions
Web Page Requests not showing up in Application Overview
I have a measure that gets results for a specific argument. In this example, I only care about the string value “Target”. Notice I’ve added Target to the Value field. This isn’t working. Does anyone know what I’m doing wrong?
Restrict transaction based measure by agent
The use of visit rate calculation
How to capture the user details who executed a servlet or webrequest in a java application hooked up with APPMON?
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
