• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Venkata T. · Oct 05, 2013 at 03:02 PM · business transaction
BT not showing the right values
i am planning to capture sql count from cart page based on the number of items per cart. So i have cart page in the filter section and sum of sqls in the calculation section and cart count in the splittings. Bur for some reason i am not seeing the right sql count. Am i missing something in the BT definition?
It is splitting correctly based on number of items per cart. But i am not seeing the right sql count for each transaction.
For the view cart time, i tried last, sum aggregations but still no luck...
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Rick B. · Oct 07, 2013 at 08:32 AM
Only thing I can mention from the screenshots is that the parentheses in SQL Count for Cart are not necessary...
Comment
0 Show 0 · Share
avatar image
Answer by Andreas G. · Oct 05, 2013 at 06:52 PM
What value do you see as a result? can you export a session and send it over? The BT looks good to me. The only other option you can try is "Count" for result aggregation
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Related Questions
Configuration for JUnit Test Perfomance View (Business Transaction, Measure, Sensor pack methods)
Renaming splittings in BTs
matches and equals
What is the Regex to omit words with sequence of uppercase letters from a group of sentences.?
create business transaction to measure purepath taking longer than 10 seconds from specific IP address
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
