In dT 6.2, there are charting options available under the Infrastructure link on the left-hand menu. These charts only allow Host Monitoring metrics to be selected, and no custom metrics can be added.
If I use a standard chart, I can also select Host Monitoring metrics, but they don't appear on the graphs. I always see "No measurements Available".
What is the purpose of the Infrastructure charts, and how do I create custom metrics on them?
Answer by Reinhard W. ·
Derick,
with dT 6.2 there is a global view of infrastructure metrics, independent of the systemprofiles agents are mapped into. Prior to 6.2 you could only show host metrics on a chart that had it's source set to a systemprofile and you would only see host metrics if the agent mapped into that system profile.
The charts listed under Infrastructure are meant to allow a display of these global metrics, whereas you can still display host metrics from a systemprofile with the 'normal' charts.
Reinhard
World Map is not able to show data in DynaTrace Client
How to build custom dashboards and alert based on BrowserFamily or Referrers?
Cycle through AppMon Web Dashboards and Automatically Change System Profiles
Error count web dashboard displaying values always in Green
Chart a Business Transaction filtering with two different splitting values
