• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Elena H. · Aug 24, 2015 at 07:25 AM ·
Problems to instrument Tibco 5.4 agent on Solaris 8
Our customer is trying to start an agent for Tibco 5.4 on Solaris 8. We are using Dynatrace 6.1.
They've added the following line in .tra file:
#Dynatrace
java.extended.properties=-agentpath\:/usr/tibco/products/Dynatrace/dynatrace-6.1.0/agent/lib/libdtagent.so\=name\=OURENVTibco_OURAPP_OURMACHINE_OURSERVER\,server\=XXX.XXX.XXX.XXX\:9998
And they've got the following errors in logs:
Error occurred during initialization of VM
Could not find agent library in absolute path: /usr/tibco/products/Dynatrace/dynatrace-6.1.0/agent/lib/libdtagent.so
They double-checked the library exists in the specified path.
We've seen in this link
https://community.dynatrace.com/community/display/... Tibco 5.4 and Solaris 8 aren't certificated and supported. And they got starting aTibco agent on version 5.11.
Could it be the reason for which they can't start the agent?
If something it's not clear, don't hesitate asking us.
Thanks in advanced.
Elena.
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Elena H. · Aug 24, 2015 at 12:16 PM
Ok. Thanks a lot, Christian.
Elena.
Comment
0 Show 0 · Share
avatar image
Answer by Christian S. · Aug 24, 2015 at 12:06 PM
hi Elena,
ok, based on your ldd output it's really the case that some libraries/versions are not found on Solaris 8. so you were right, Solaris 8 is really not supported.
Christian
Comment
0 Show 0 · Share
avatar image
Answer by Elena H. · Aug 24, 2015 at 11:51 AM
Hi Christian,
We are sure the agent is 32 bit. But the customer has tried to install 64 bits agent and she's got the same errors.
They got the following launching ldd command:
our_machine:/usr/tibco/products/Dynatrace/dynatrace-6.1.0/agent/lib> ldd libdtagent.so
libCrun.so.1 => /usr/lib/libCrun.so.1
libkstat.so.1 => /usr/lib/libkstat.so.1
libc.so.1 => /usr/lib/libc.so.1
libc.so.1 (SUNW_1.22) => (version not found)
librt.so.1 => /usr/lib/librt.so.1
libsocket.so.1 => /usr/lib/libsocket.so.1
libpthread.so.1 => /usr/lib/libpthread.so.1
libm.so.2 => (file not found)
libdl.so.1 => /usr/lib/libdl.so.1
libaio.so.1 => /usr/lib/libaio.so.1
libnsl.so.1 => /usr/lib/libnsl.so.1
libmp.so.2 => /usr/lib/libmp.so.2
/usr/platform/SUNW,Sun-Fire-15000/lib/libc_psr.so.1
libthread.so.1 => /usr/lib/libthread.so.1
They got this launching ldd command for 64 bits library:
our_machine:/usr/tibco/products/Dynatrace/dynatrace-6.1.0/agent/lib64> ldd libdtagent.so
warning: ldd: libdtagent.so: is not executable
libCrun.so.1 => /usr/lib/64/libCrun.so.1
libkstat.so.1 => /usr/lib/64/libkstat.so.1
libc.so.1 => /usr/lib/64/libc.so.1
librt.so.1 => /usr/lib/64/librt.so.1
libsocket.so.1 => /usr/lib/64/libsocket.so.1
libpthread.so.1 => /usr/lib/64/libpthread.so.1
libdl.so.1 => /usr/lib/64/libdl.so.1
libaio.so.1 => /usr/lib/64/libaio.so.1
libnsl.so.1 => /usr/lib/64/libnsl.so.1
libmp.so.2 => /usr/lib/64/libmp.so.2
/usr/platform/SUNW,Sun-Fire-15000/lib/sparcv9/libc_psr.so.1
libthread.so.1 => /usr/lib/64/libthread.so.1
Thanks a lot.
Elena.
Comment
0 Show 0 · Share
avatar image
Answer by Christian S. · Aug 24, 2015 at 09:07 AM
hi Elena,
you're trying to inject the 32-bit agent, so are you sure that the process is really 32-bit?
you could try the 64-bit agent by just modifying the path to ".../agent/lib64/libdtagent.so...".
HTH, Christian
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
6 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
