I'm installed DT agent on application having Direct Web Remoting Framework but I'm not getting adequate details in PP. Please find attached screenshot for PP details.
Kindly suggest if i need to enable any specific sensor pack for this.
Regards,dwr-details.xlsx
Amol
Answer by Andreas G. ·
I would do a CPU Sampling to see where all of this time is spent. Maybe this particular framework uses some unsupported thread pools. In this case the workaround could be to create custom entry points to at least get PurePaths for the time that is currently booked on your doPost method.
