My cba process refuses to start, looking in the log is shows me that the "Application recognition component" failes to init. It seems there are errors in the packetmatchconfig.xml file.
"group is not allowed for content model", removing the record gives me the next in line.
1) can I fix this? Can I replace file back to default
2) how can this happen, has this to do with an 12.2
KR Henk Stobbe
Atos Groningen
Answer by Atos A. ·
fyi, the "broken" file is identical with the .before.upgrade one, the size is 30841, and I have a bck and a default one 50104 in size
Answer by Atos A. ·
It is an empty environment,, is it a big issue to replace the file with the default one?
Ahh, no problem, just give me exact build number of the AMD, either from ndstat command or /usr/adlex/config/applications.xml file.
Answer by Atos A. ·
No sorry, the file was not touched, attached peace of logging. I noticed in console cba-agent not talking to cba,
