• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Brad L. · Sep 16, 2015 at 02:06 PM · agent uem apache
UEM not working when going through two apache layers registered to two different profiles
We have a unique setup in our environment where an application leverages a shared apache instance with many proxypass configurations on it. They did this so the user always sees the 1 URL/DNS while the URI is actually spraying around to multiple configurations elsewhere.
The issue that has seemed to cause us is when the shared apache server is registered to DT 'Profile 1' and the secondary apache server that receives the proxy traffic is registered to DT 'Profile 2'.
When running in this setup two things do not seem to be working.
1. Application tagging is not working on purepaths - all purepaths fall into the 'default application' grouping even when the application definition is changed to '/'.
2. UEM will not work when set on the 2nd apache server. It seems to conflict with hitting the first apache server and refuses to perform the injection. Using the UEM test tool - it complains that the agent is not registered to this profile.
I am wondering if anyone has faced this type of issue before or if anyone has any ideas to solve it?
The only thing I can come up with is to:
1. Register the first apache server to this profile. However, this is not an option as 'Profile 2' is secure and cannot take on the purepaths from the first apache server which is shared.
2. Tell the application that if they want this to work, users must hit the applications apache servers directly without using a proxy frontend.
Thank you
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Florent D. · Sep 16, 2015 at 02:20 PM
Hi
the UEM configuration is profile specific so having 2 agents in 2 different profiles will be an issue.
The same applies to applications. Purepaths cannot span across profiles anyway.
So in your instance, I would consider not having an agent on the proxy to see if all purepaths are categorized correctly (application) and that UEM works.
If it works (as it should), you might have to put the 2 apache instances in the
same profile to see what happens with UEM.
Regards
Flo
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
9 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
Monitoring HTTP proxy requests with UEM
Webserver log printing cookie value
UEM - huge Elapsed time between last Web Request and OnLoad Event inside User Actions
Dynatrace 6.3 - Tomcat/Java Agent can collect UEM data?
About How to install the Java agent and WSAgent on same *nix OS.
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
