I am new to Dynatrace.
We have installed the Dynatrace r6.2 in distributated manner.
i.e 1. Box 1 - Dynatrace Server.
2. Box 2 - Dynatrace collector.
3. Box 3 - APP + Dynatrace Agent.
But we are not finding the entry of Dynatrace collector in the Dynatrace sever. while trying to access the Dynatrace Server through Dynatrace client.
1.Do we need to do any extra configuration so that Dynatrace collector will be able to communicate with Dynatrace server.
2.Do we require to install the support technology component in the Dynatrace server box also.
Cheers
Jay
Answer by Harald Z. ·
Jay,
if the DT collector is installed on a different box than the server, you have to change the settings for the connection in /opt/dynatrace/collector/conf/collector.config.xml
In collectorconfig set the attribute serveraddress to your DT server and restart the collector
-Harald
Thanks a ton Harald. Now DT collector is able to communicate with DT Server.
I will be grateful to if you can confirm whether the support technology component of the DT installer should be installed on the DT server only box.
Cheers
Jay
