Hi all,
In the documentation, in the filters column of DMI report definition, Data is defined as "specify Data to filter input data" and Results is defined as "Specify Results to filter the report definition results before they are put in the report. I'm not too clear on the Results part - does it mean that the selected metrics will undergo some sort of transform or operation before displaying? And what caused the different results in reporting if we choose Data or Results?
Thanks for the help.
Chris
Answer by Adam T. · Nov 02, 2015 at 02:04 PM
Ok, so maybe let's go on with a simple example. Two users go to http://mydomain.com/myFavoritePage.aspx.
At 10:00 user1 calls that page 20 times, and 10 operations are slow.
At 10:05 user1 calls that page 20 times, and there were no slow pages.
At 10:10 user2 calls that page 10 times, and there were no slow pages.
So those 3 lines from above, will be entered in the database, as 3 separate records (each record contains information about user & number of operations & number of slow operations)
When you create some DMI report, for that activity, and you set condition to show only entries with slow pages (slow pages > 1), without time dimension, then:
a) if the filter 'slow pages' > 0 is set with "results",
b) if the filter 'slow pages' > 0 is set with "data",
Thanks Adam! This example is clear and easy to understand. Now my question is, how would the logic runs if the time dimension is applied with 1 hour resolution?
For example,
At 9:55 user1 calls that page 20 times, and 10 operations are slow.
At 11:00 user2 calls that page 20 times, and 10 operations are slow.
In such case, both options 'results' & 'data' will show the same report, with:
9:00 mentioning user1 with 20 operations, out of which 10 were slow
11:00 mentioning user2 with 20 operations, out of which 10 were slow
Activity of both users, between 10:00 - 10:59, does not meet the conditions, neither for 'results' nor for 'data'.
So 'results' option = take user activity for '1 period' data, aggregate to 1 hour, then check condition (per hour) and show the matching ones.
The 'data' option = take user actvity for '1 period' data, choose periods for which the condition is matched, then aggregate only those and show on the report.
Learn the enhanced capabilities of the next generation Dynatrace AI root cause analysis and how to feed it with your own data sources.
Wednesday, February 20, 2019
Register today!
Register today!
Would you like to have an early taste of what we have cooked up for 2019? We would love to hear your feedback and improve some of the new features. Check NAM 2019 Beta release notes.
Sign up today!
Several Report Questions 5 Answers
Change all report filters in one go 4 Answers
Number of lines in a (synthetic) report 2 Answers
Transposed Table Does Not Appear as Intended 1 Answer
Exclude Exception Class 2 Answers
