question
Matthew K. avatar image
Matthew K. asked ·
Help with Monitoring Time Range option
From the Doc:
Select a non-default Monitoring Time Range.
The list is active only for Enterprise Synthetic and sequence type of alerts and only if the Transaction source dimension is filtered to Transactions (Active Monitoring). Use this option if you wish to evaluate alert condition on the Enterprise Synthetic data covering interval different than the default Last monitoring interval (5 minutes by default) used by the CAS. As the Enterprise Synthetic transactions spanning across two consecutive intervals will not raise an alert, even if they meet the defined alert conditions, you can select a CAS independent time range to avoid such situations. You can choose among the following predefined ranges: 10, 15, 30 and 60 minutes.
Question. Does this option cover the alert if we are running ESM transactions every 15 minutes? So for example, we need to set this option to 15 because if it is set to the last interval or 10, the CAS would miss the alert? If yes, what if it were set to 20 or 30 and ESM scripts run every 15 min? Also, does this impact or take precedent over the “Raise after “x” interval(s) under Propagation settings in any way or completely different? Thanks in advance for the help.
alertingnam servernamesm
Kalle L. avatar image
Kalle L. answered ·
I haven't been able to find any documentation regarding this "Monitoring time range" option - does anything exist?
4 comments Share
Hello anonymous user
If you are asking about the CAS then please follow the link for the configuring section-specific time ranges.
https://www.dynatrace.com/support/doc/dcrum/cas-and-reporting/tools/dmi/new-report/adding-editing-or-deleting-a-report-time-range/
Below link is about the Enterprise Synthetic.
https://community.dynatrace.com/community/display/ENTSYM125/Adding+a+Time+Range+to+a+Schedule
Babar
0 Likes 0 · ·
We're talking about defining alerts at the RUM console based on Enterprise Synthetic data. I'm afraid the links you provided aren't related to this issue...
0 Likes 0 · ·
Not only the propagation settings; ESM data has an additional setting under "Detection settings" -> "Monitored metric" -> "Monitoring time range". That is what we're trying to get further info on.
0 Likes 0 · ·
Vinay C. avatar image
Vinay C. answered ·
Hi @Matthew k,
We are also struggling with the same scenerio to generate alerts in the range for predefined like: 20 or 30 mins. Our requirement is to generate alerts for 3 consecutive failures of any ESM script.
Kindly let us know if you have find any solution to this requirement.
Many Thanks,
Vinay Chaudhary
Share
