question
Ryan S. avatar image
0 Likes"
Ryan S. asked ·
Secure Communication between Collector and F5(Proxy)
I'm trying to find a way to have secure communication between my collector and proxy, such as two-way SSL or TLSv1.2 or something, is this possible? What protocol is the communication between the collector and proxy?
I know that you can set a username/password for the collector to talk to the F5 but security is looking for more than that.
Any help or explanation would be appricated!
configuration6.5serverproductioncollectorsecurity
1 Answer
Andreas G. avatar image
0 Likes"
Andreas G. answered ·
Hi Ryan
Are you talking a proxy between Agent and Collector or Collector and Server?
Andi
· 1 · Share
Hi Andi,
It ends up there was a bit of a mix up in communication between security and myself. As I understand we already do one way SSL TLSv1.2 from the Collector to the Server which I told them, but they were asking it it was possible to make a two way SSL connection from the collector to the F5 before the server. I told them that this was not supported.
0 Likes 0 · ·
