• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
        • Enterprise Synthetic Monitoring
      • Synthetic Classic
        • Synthetic Classic Open Q&A
  • Home /
  • Public Forums /
  • Synthetic Classic /
  • Synthetic Classic Open Q&A /
avatar image
Question by Jeff K. · Feb 15, 2017 at 10:54 PM · dynatrace recorder tests setup tests https
Test is using TLS1.0 to make a connection, even when 1.2 is available on both sides.
I have a simple 1 step test that does a login. For whatever reason, this particular test uses TLS1.0 when it creates a connection to our site. I know that the Synthetic node is updated and able to use TLS1.2, because it uses it for many other tests. I also know that our webserver is setup to use 1.2, when you hit it with a normal browser it uses TLS1.2 by default.
Does anyone know why Synthetic would not automatically use 1.2, or a way to force it to?
Comment
People who like this
0 Show 0
â–¼
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
Up to 10 attachments (including images) can be used with a maximum of 52.4 MB each and 262.1 MB total.
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Vaughn P. · Feb 24, 2017 at 05:33 PM
support case submitted to dynatrace but adding comments into this post:
The reason the test is using the TLS 1.0 as the MN PA currently has FF24 browser agent which only support TLS 1.0 so if you have site with TLS 1.1 or 1.2 support it will downgrade to next supported TLS version. See below TLS support based on browser versions.
https://en.wikipedia.org/wiki/Template:TLS/SSL_support_history_of_web_browsers
I would recommend upgrading the MN PA to the latest IE11, FF38 and CH46 browser agents that support TLS 1.1 and 1.2. The upgrade downtime is typically 3-4 hours so please advise best time. We prefer early business hours as after 5PM can be a challenge.
Comment
0 Show 0 · Share
â–¼
avatar image
Answer by Bill H. · Feb 16, 2017 at 06:16 PM
Hi Jeff!
The reason why only that test is having an issue is that it may be running from a different browser agent than the others. If this test is running from an FF Agent, add the following in the first step using control target window to correct this issue:
var prefs = Components.classes["@mozilla.org/preferences-service;1"].getService(Components.interfaces.nsIPrefBranch);
prefs.setIntPref("security.tls.version.min", 3);
prefs.setIntPref("security.tls.version.max", 3);
Please let us know if this resolves your issue. If not, the next step would be to create a support ticket to investigate further with the test name. Thanks for your inquiry!
Comment
0 Show 3 · Share
â–¼
avatar image Jeff K. · Feb 17, 2017 at 07:54 PM 0
Share
What do you mean when you say "add to the first step?" should I enter these into the parameters section? or is it like an HTTP step?
avatar image Jeff K. · Feb 21, 2017 at 07:20 PM 0
Share
So I figured it out, and added this as a 'custom' step and entered your Javascript (and it is indeed a Firefox script). Unfortunately when I run the test I'm seeing the following error: Javascript Error Details: Step 1, action 2: TypeError: Components.classes is undefined
avatar image Bill H. · Feb 22, 2017 at 02:41 PM 0
Share
Jeff,
I'm sorry that you were unable to find resolution to the issue. If you haven't already done so, please open a ticket and we will be happy to further investigate the problem. Thanks.
Join the conversation!
First steps in the forum
Community User Guide
LIVE WEBINAR
"Power Demo: Software Intelligence for Cloud Infrastructure"
DECEMBER 12, 10:00 AM GMT / 2:00 PM ET
Register here
Live webinar: Ensuring Digital Business Availability with Dynatrace
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 10, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
Follow this Question
Answers Answers and Comments
16 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
Instant Test SOAP api - executing Mobile tests 1 Answer
Why do some Backbone instant tests run successfully through the portal and always fail via SOAP API? 3 Answers
Why is there a limitation on backbone tests? 1 Answer
Saving script to GPN failed error 1 Answer
Why so many inactive chrome nodes? (C)* 1 Answer
Forum Tags
configuration summary mobile monitoring tests timeout synthetic monitoring reports flash synthetic mobile guardian synthetic percentile test management w3c web recorder rest api errors dashboard waterfall chart 2017-Q2 release number login retry on error synthetic monitoring private peer monitoring firefox flex sliverlight dynatrace advanced synthetic account windows recorder last mile monitoring interactive charting webinar gomez 2014-Q3-SEP dynatrace recorder speed index high five award backbone load testing community awards ftp chrome private last mile benchmark leapsecond web performance monitoring sms alerts scoe news synthetic sla report portal alerting performance monitoring web services notifications native mobile app reports third party apr-2017 setup tests browser agent april-2017 chart cloud wait perspective report threshold certificate appmon scripting custom action recorder agent custom code https emails
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
    • Synthetic Classic
