Web Check for certain time frame possible?
jens_wommer
Newcomer
Is it possible to limit Web Checks to certain time frames? For instance 5 to 11 pm. This would be helpful because of server and website maintenance.
Philipp_Kastner
Dynatrace Pro
Dynatrace Pro
Hi Jens,
currently it is not possible to set a maintenance window for web checks. However, this is on our roadmap, not only for web checks but as a more general feature for Dynatrace.
I'll keep you updated.
Kind regards, Philipp
Philipp_Kastner
Dynatrace Pro
Dynatrace Pro
Hi @Jens W.,
in the meantime we do support maintenance winodws configured via the UI or API, you can find all the details here https://www.dynatrace.com/news/blog/manage-planned-downtimes-maintenance-windows/
Your synthetic monitors will be still executed. However, alerting will be turned off during the definied periods.
