question
Shawn G. avatar image
Shawn G. asked ·
Custom Problem notification to HP Openview
We are attempting to configure our DT SaaS Managed instance to send alerts to HPOV via a custom webhook. We are able to successfully test the exposed interface, but when we configure the webhook in DTSaaS we are receiving the following error.
2017-04-06 16:12:53 UTC WARNING [<default,1rqyj3bmqj,tab-ylYczhMf974w>] [IntegrationConfigServiceImpl] POTENTIAL HACK ATTEMPT: user tried to configure a forbidden URL as Webhook endpoint: https://<HPOVendpoint>/api/om/opcmsg
I am wondering if we are receiving this error due to a certificate issue or if DTSaaS is blocking the request because we are pointing to a host directly as opposed to a VIP/DNS alias.
Thank you for your help.
Shawn Givan
configurationDynatrace Managedalerting
Wolfgang B. avatar image
Wolfgang B. answered ·
Yes it seems that our detection of misuse of the webhook in private network space was a little too strict. I will ask our devs if we have some sort of whitelist in place.
1 comment Share
Wolfgang,
Do you know if there has been any movement on this? Or do you need an RFE?
Shawn Givan
0 Likes 0 · ·
Shawn G. answered ·
Wolfgang,
Awesome. Thank you.
Shawn Givan
Share
