question
Yos N. avatar image
Yos N. asked ·
No problem is starting after killing w3wp process (application pool)
Hi guys,
Prospect was test dynatrace and kill application pool process but no problem was started because of that ? Is there any explain for that?
Also prospect ask what is the amount of time that dynatrace decide that the problem is starting and the alert is fired ?
Yos @gil g.
process groups
1 Answer
James K. avatar image
James K. answered ·
Most of the problems the AI Engine detects aren't as simple as "process is down, fire alert" but instead look to see what transactions and requests are failing for real users and then attempt to isolate what caused these failures or slow downs (based on baselines gathered over time). So if the process is down but not a significant number of actions are actually failing then it is unlikely a problem would be reported out of the box. The idea behind this is with cloud based architectures and microservices a process or host goes down but either this is expected or it recovers automatically so you wouldn't want an alert unless users end up being affected. This is why it is important to make sure your deployment is being "fed" enough data so that the AI can learn and have good data to work with.
Of course if you would like more sensitive alerts these can be configured. In the case you're testing you could set up alerts at the process group level that would create a problem if fewer than X instances of that process are active. You can also select "key requests" which will create problems more quickly if they experience problems (e.g. a checkout transaction on an eCommerce site). More info on problem sensitivity adjustment here:
https://www.dynatrace.com/support/help/problem-res...
James
1 comment Share
Hi James
Thanks for the detailed answer
The link is good! but needed to update the pictures that has Ruxit logo :-)
Yos
0 Likes 0 · ·
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions session replay diagnostic tools permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
