question
Robert P. avatar image
Robert P. asked ·
Broker monitoring using Dynatrace Managed and appmon/dcrum
what are the best options for monitoring a broker environment, we have Dynatrace managed, Appmon and also DCRUM.
appmonDynatrace Managedoneagentmonitoringnam
1 Answer
Harshal P. avatar image
Harshal P. answered ·
Hi Robert,
For DC RUM, you can define the Broker as a software service with the HTTP analyzer and analyze the corresponding web services. That gives you a great fault domain isolation.
Depending on the Broker version,you can use the following plugin in App Mon to check Broker metrics. I would highly recommend to instrument this plugin in QA/Dev Broker (
https://community.dynatrace.com/community/display/...
Or you can install an App Mon agent. Please note that App Mon agent is per execution group within the broker.
I believe Dynatrace support for broker will be here in the next 3/4 months.
Hope this helps.
Harshal.
2 comments Share
Great i will have a meeting about the plugin with dev... thank you!
also cuestioning about xml/soap for webservices... it is neccesary for this service monitoring too?
@Harshal P.
0 Likes 0 · ·
Hi @robert p.
If you define the Message Broker in DC RUM with the HTTP analyzer, it will automatically pick up the Web Services. No additional configuration is required.
0 Likes 0 · ·
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions diagnostic tools session replay permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
