Is it possible to trigger AWS Auto Scaling for dynatrace?
kohei-saito
Helper
I have a question about of AWS Auto Scaling with dynatrace.
How can we trigger AWS Auto Scaling by the dynatrace information such as "Problem"?
For example, I guess that we may be able to automatically scale instances, setting up AWS Auto Scaling API to "Settings">"Integration">"Custom integration">"Webhook URL".
If dynatrace can trigger AWS Auto Scaling, please tell me how to do.
Thanks.
Kohei
pawel_brzoska
Inactive
Check here:
https://www.dynatrace.com/news/blog/auto-mitigation-with-dynatrace-ai-or-shall-we-call-it-self-healing/
andreas_grabner
Dynatrace Guru
Dynatrace Guru
Also check out my GitHub repo with some Lambda Functions that connect AWS Services with Dynatrace. There is one Lambda function called handleDynatraceProblemNotification you can check out: https://github.com/Dynatrace/AWSDevOpsTutorial
Andi
Contact our DevRel team through devrel@dynatrace.com
