Dynatrace SaaS: Test Automation?
matthew_eisengr
Inactive
Wondering if you can do test automation like you can with AppMon here: https://www.dynatrace.com/support/doc/appmon/conti...
Specifically can you choose a baseline and mark other tests as improved, degraded, volatile?
3 REPLIES 3
rick_boyd
Mentor
Hey Matt,
(what's up?!)
@Andreas G. was telling me about doing differentials for Load Tests with Dynatrace, you might want to see if his use case can match up with yours. Low level tests are not supported, not sure what the roadmap looks like on that
Rick B
There's a good perf clinic online that covers a lot of what capabilities around load test analysis are currently available here too:
https://youtu.be/kwH64up-UAs
sonja
Inactive
There's an additional blog post from Andi that you should also check out (Unbreakable DevOps Pipeline: Shift-Left, Shift-Right & Self-Healing): https://www.dynatrace.com/news/blog/unbreakable-de... or the Online Perf Clinic if you prefer to listen to him directly 😉 https://www.youtube.com/watch?v=r-0xunTqwQ0&list=P...
