I have trouble getting the UEM working on my app. I have a Nginx webserver agent installed and working fine on aws, but nothing is injected in my web page
I thought that the javascript agent was automatically injected by the webserver agent. Is it the case? Is there something that I should do on my application server?
I use Appmon 7.0 on Ubuntu 16.04LTS
I installed the web agent with ansible
Thank you in Advance
@Leszek Sobiecki
Answer by Youssef M. ·
Hello Babar,
Thank you for your response, How can i check if these headers do not get blocked in my environment?
Answer by Babar Q. ·
Hello Youssef,
Did you enable the UEM data for this application?
e.g. System Profiel > User Experience > Capturing slide to the right most.
Make sure that the HTTP headers x-dtPostBody
, x-dtHealthCheck
, and x-dtAgentId
do not get blocked in your environment. The UEM Health Check needs them to work properly.
Review the below link for the UEM health check.
https://www.dynatrace.com/support/doc/appmon/user-...
Babar
