question
野愛 小. avatar image
野愛 小. asked ·
How instantly the Problem appears in UI and is notified?
I have a question about how instantly the Problem appears in UI and is notified.
I think that it takes a certain amount of time from when abnormality detection on OneAgent to when appearing the Problem in Web UI and email notification.
Could you tell me how long it takes generally?
And how frequently do you update the information in the problem(Web UI)?
In this case, I assume that we set 0 to the following setting in the Alerting profile.
"Send a notification if a problem remains open longer than [0] minutes."
I suppose that the notifications of Problems send in near real time by this setting.
Noah Kobayashi
alertingdynatrace saas
1 Answer
Wolfgang B. avatar image
Wolfgang B. answered ·
Yes setting the duration filter to 0 in AlertingProfiles means that problems are delivered instantly. All notifications are sent immediately when the problem is opened but the Web UI has a refresh of one minute. So in worst case, if the problem opens right after a refresh you will get notified before you see the problem in our webUI.
1 comment Share
Hi Wolfgang,
Thank you for your response.
Could you tell me generally how long it takes from when OneAgent get abnormal performance data to when the Problem notifies via email?
Our customer needs the figure.
Thanks, Noah
0 Likes 0 · ·
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions diagnostic tools session replay permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
