24 Jul 2018 09:24 AM - last edited on 16 Mar 2023 03:06 PM by Ana_Kuzmenchuk
I'd like to know the meaning of "Problem ID" as seen in "Problems".
When I go to "Problems", I can see various problems in the list and each problem has a "Problem ID".
What I mean here by "Problem ID" is different from a uniquely defined ID for each problem.
This is an example image for "Problems"
Like the above image, "Problem ID" of this problem is "474".
This "Problem ID" seems not unique ID for each problem but something like ID for grouping or categorising because the same number occurs again and again.
In addition, each "Problem" seems to have the unique ID in the URL parameter like the following.
pid=0123456789_9876543210
Note) Actually, this number has larger digits.
Then, what is the "Problem ID "?
If this means something like ID for grouping or categorising, what are the criteria for grouping?
Kohei Saito
24 Jul 2018 11:25 AM
The pid you mentioned is the unique problem id, it's for for example to fetch problem details via the API.
The shorter problem number is just for quick reference. It won't be unique over large timeframes but can be used for quick reference, for example if you wan't a coulleauge to take a look at a specific open problem.
24 Jul 2018 05:55 PM
One thing to add: The Problem ID values do not have any secret meaning. There's no grouping or categorizing based on ID values, they are just random.
25 Jul 2018 08:44 AM
Hi @Patrick H. & @Joseph M. H.,
Thanks for your comments!
It is a little surprising to me that Problem ID is used as only quick reference not as grouping ID of Problems.
However, when I come to think of it, we can refer to each problem using ProblemID as something like an index.
I understand Problem IDs are just random, too.
Thank you very much.
Kohei Saito
