Hidden values in SQL statements
antonio_delisa
Newcomer
Hi all,
I'm trying to extract significant KPIs from the SQL queries detected by Dynatrace SaaS.
Within the SQL statements some values are hidden and are represented by the "?" character.
How can I display them in clear text?
Thank you,
AD
4 REPLIES 4
Joe_Hoffman
Dynatrace Leader
Dynatrace Leader
Antonio, I believe those are Bind variables you are seeing. Bind variable capturing is coming soon and is available as a beta feature for certain technologies. I suggest you reach out to your sales team and explore if it can be enabled for your tenant.
I believe this is coming but only for Managed clusters for the time being - see Michael Kopp's posts here: https://community.dynatrace.com/spaces/483/dynatrace-product-ideas/idea/183009/rfe-capture-sql-bind-...
James is correct (as usual). Only for Managed.
antonio_delisa
Newcomer
Thanks to all for your reply. I'm asking to sales team if it can be enabled.
