08 Sep 2018 06:38 AM - last edited on 19 May 2023 06:55 AM by Michal_Gebacki
Good Day
Ihave a client that needs to monitor Biztalk as they are migrating from Appmon to Dynatrace Managed / SaaS.
Is there out of the box support for Biztalk, not Host metrics but deep dive? On Appmon a plugin was available.
Has anybody done this before and what insight can be shared.
Do's and don'ts
07 Nov 2018 10:21 AM
I'm also looking for info on Biztalk monitoring with Dynatrace. Mias, did you eventually get any help via other channels?
19 Nov 2018 12:10 PM
Hi Guys,
I also have a client using BizTalk.
The application is recognised as a .net application, but there is not much interesting to see. No consolidated service flow,... I think some extra development needs to be done here.
21 Nov 2018 11:12 AM - last edited on 16 Oct 2023 03:54 PM by random_user
Please go and upvote the RFE and submit your comments / requirements:
23 Jun 2021 07:03 AM
Hi Guys,
Any update for this topic ?
I need to monitor some Biztalk services.
23 Dec 2022 10:06 AM
Hello all,
There is an extension for BizTalk in Dynatrace Hub, that is supported and developed by our partners. You can check it out here:
https://www.dynatrace.com/hub/detail/biztalk-plugin-20/
25 Dec 2022 07:20 AM
I already used this plugin, but its only showing the metrics and not the services.
