easyTravel runEasyTravelNoGUI.sh - keep it running endless
skrystosik
do you have any idea how to keep easytravel working endless using runEasyTravelNoGUI.sh
I'm starting it with nohup but after some time easyTravel is going down:
2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad]     CustomerBaseLoad - Procedure inprocess DBMS state changed to STOPPING. Scenario hosts after change:
2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad] B2BBaseLoad - Procedure inprocess DBMS state changed to STOPPING. Scenario hosts after change:
2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad] MobileBaseLoad - Procedure inprocess DBMS state changed to STOPPING. Scenario hosts after change:
2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad] MobileBrowserBaseLoad - Procedure inprocess DBMS state changed to STOPPING. Scenario hosts after change:
2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad] HotDealBaseLoad - Procedure inprocess DBMS state changed to STOPPING. Scenario hosts after change:
2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad] HeadlessCustomerBaseLoad - Procedure inprocess DBMS state changed to STOPPING. Scenario hosts after change:
2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad] HeadlessAngularBaseLoad - Procedure inprocess DBMS state changed to STOPPING. Scenario hosts after change:
2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad] CustomerBaseLoad - Procedure inprocess DBMS state changed to FAILED. Scenario hosts after change:
2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad] B2BBaseLoad - Procedure inprocess DBMS state changed to FAILED. Scenario hosts after change:
2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad] MobileBaseLoad - Procedure inprocess DBMS state changed to FAILED. Scenario hosts after change:
2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad] MobileBrowserBaseLoad - Procedure inprocess DBMS state changed to FAILED. Scenario hosts after change:
2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad] HotDealBaseLoad - Procedure inprocess DBMS state changed to FAILED. Scenario hosts after change:
2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad] HeadlessCustomerBaseLoad - Procedure inprocess DBMS state changed to FAILED. Scenario hosts after change:
2018-10-13 13:48:09 CmdLaunche TRACE [BaseLoad] HeadlessAngularBaseLoad - Procedure inprocess DBMS state changed to FAILED. Scenario hosts after change:
Regards, Sebastian
3 REPLIES 3
skrystosik
Ok for those who also needs to run it continuesly, I've added this script to crontab to run on restart and in this way it works all the time. For Ubuntu:
@reboot /opt/easytravel-2.0.0-x64/runEasyTravelNoGUI.sh
Regards, Sebastian
jeffery_yarbrou
Dynatrace Organizer
Dynatrace Organizer
You may want to run it this way.
  1. @reboot/opt/easytravel-2.0.0-x64/runEasyTravelNoGUI.sh > /dev/null &
This will make sure you are sending the standard out to /dev/null and running it the background.
Thx but actually I'm sending logs to file because of some reasons 🙂 I've posted my command as an example.
Regards, Sebastian
