Other filter seems to be not able to apply after ..."dependency" filter is applied
It appears that as long as the dependency-filter is not applied, I can apply as many other kind of filter as I want.
But once dependency filter is applied, other filters can't be apply anymore.
Is that correct? Anyone can correct me if I am wrong? Or if there is any workaround if my observation is true.
I am thinking this might be a candidate for good RFE......
Aamir_khan
Participant
You can still apply filters you just need to click on the two filters already applied and based on which side i.e "mya...." or "....BP" then you can apply other filter
