question
Alberto D. avatar image
Alberto D. asked ·
What port use Active gates from same environment to communicate each other
we are configuring a New managed installation where, because of firewall issues, agents won't have access to the Dynatrace Server node but they will make the connection through Active Gates. In order to get HA and to remove a point of failure we want to communicate the tenant Active Gates each other. The question is, what port do they use for that? 9999 or 443?, it's necessary to open the right port in the FW.
The following page does not answer the question:
https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-activegate/configuration/which-network-ports-does-activegate-use/
Thanks in advance.
Alberto.
Dynatrace Managedactivegatenetwork
Julius L. avatar image
Julius L. answered ·
ActiveGate opens the 9999/tcp by default (you can set a different port if required, but ports below 1024 won't work since the ActiveGate is not running as a privileged user). It always agent--->activegate (cluster or environment)--->cluster node or agent--->cluster node.
ActiveGates do not communicate with each other at all, so you don't need to open any connections between them. If you need HA in a zone, you just need to set up two ActiveGates in the zone. Each agent will receive endpoint addresses of both gateways, so when the connection is lost, the agent automatically connects to other available ActiveGate.
1 comment Share
Cluster node listens on 443 and 8443 for agent communication (8443 for older installations for compatibility reasons, 443 for new cluster installations). So you need to open the appropriate port from ActiveGates to your cluster nodes.
0 Likes 0 · ·
Babar Q. avatar image
Babar Q. answered ·
Hello @Alberto D.
Environment ActiveGates do not talk to each other but only to the Cluster ActiveGate on port # 9999. ActiveGates will be automatically HA if you install more than one in the same environment, therefore, no manual intervention required.
You will have to open the port # 9999 from OneAgent to the Environment ActiveGate and port # 443 from Environment ActiveGate to Dynatrace Server.
Babar
Share
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions session replay diagnostic tools permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
