Oracle Database Insight, what difference would it make if I installed OneAgent in the ORacle Host, but in cloud-infra mode?
Great to hear that Oracle database insight is finally here (https://www.dynatrace.com/news/blog/oracle-database-insights-early-adopter-release/ ) !
So I would like to ask here first the question that most customer would ask, what would be the difference between install cloud-infra-OneAgent in Oracle Host vs install full-stack-OneAgent in Oracle Host?
Reason for customer to ask this is of course simple enough, Database Server normally has high RAM and would consume many host unit
Best Regards,
Wai Keat
skrystosik
Ai will correlate host performance as well. Oracle insights itself doesn’t need agent on host
Regards, Sebastian
Julius_Loman
DynaMight Legend
DynaMight Legend
Don't forget to use the cloud infrastructure mode on that DB host. Full-stack monitoring won't make sense unless you are running instrumentable applications on the same host.
Reasons for installing is to have more detailed and precise host metrics. Oracle DB provides just basic host metrics.
