question
Dante P. avatar image
Dante P. asked ·
Problem creation Delay
Hi! Im wondering what is the normal "Delay" that one can expect when a new problem is created.
Delay as in the "problem is created" since this abnormal metric exist. We are noticing a timing of 10 minutes aprox. is that right? This is a Managed Deploy. Is there any way to improve this delay?
Dynatrace Managedproblem detection
1 comment
1 Answer
William L. avatar image
William L. answered ·
Hi Dante,
The time between the problem occurring and the problem alerting is 5minutes. If you believe that yours is 10 minutes then you should create a support case with Dynatrace and someone will assist you further.
Billy
1 comment Share
Hey @William L. i did, this was the response.
Currently, events can take up to 7 minutes to raise an alert due to processing ques and consolidation between cluster nodes.
When you add in the time for the event threshold to be met, this can be around 10 minutes on the high end. This is planned to be improved upon in the near future.
From the technical support perspective, I don't see any errors and would only recommend recalculating your cluster sizing to ensure the cluster is not overloaded.
So im out in the blank now, i remember that the issues where hella fast, in fact in a few videos that cover problem remediation i recall the time being faster that 10 minutes.
Will check again those videos to see if i miss anything.
0 Likes 0 · ·
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions session replay diagnostic tools permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
